1 - 3 of 3 Posts
New ECS Rear Subframe Brace
Reinforce and stabilize the rear end of your MK5, MK6, or MK7 VW with our Rear Subframe Brace!
Aggressive driving takes its toll on the factory subframe which can deflect under hard cornering, especially with a larger rear sway bar.
We tightened up the rear subframe with a sturdy brace sure to hold up under even the most stressful conditions.
Click HERE for your VW MK5 GTI/Rabbit/Jetta (2005 - 2010) ECS Performance Rear Subframe Brace Upgrade
Click HERE for your VW MK6 Golf/GTI/JSW (2010 - 2014) ECS Performance Rear Subframe Brace Upgrade
Click HERE for your VW MK6 Jetta w/ Independent Rear Suspension (2011+) ECS Performance Rear Subframe Brace Upgrade
Click HERE for your VW MK7 Golf/GTI/GSW (FWD) w/ Independent Rear Suspension (2015+) ECS Performance Rear Subframe Brace Upgrade
The factory rear subframes in the VW MK5, MK6, and MK7 are perfectly capable of withstanding everyday commutes but are woefully ill-prepared to handle beefier sway bars, stiffer suspension components, and aggressive driving.
We found a sturdier solution:
With the ECS Rear Subframe Brace you can reinforce the subframe at the sway mounting points to ensure the added pressures of hard driving and stiffer components will be deflected through our brace rather than deflecting the rear subframe.
1 - 3 of 3 Posts
