1 - 10 of 10 Posts
Discussion Starter #9
thanks again everyone....this forum is extremely helpful, and makes owning a Passat that much more enjoyable....Cheers!...Nugs
will look into this after checking the connections....thank you for the input!...cheers
Here's how to disable it with vag-com:
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active
I think my existing code was 07244, changing it to 06244 disabled the brake pad warning.
1 - 10 of 10 Posts
