1 - 20 of 21 Posts
Wondering why most go for the Neuspeed rear sway bar over the lighter hollow Autotech sway bar :???: . Having less weight would be a good thing.
Does the Autotech just bolt on without any drilling?
The Autotech sway requires the drilling of a total of 2 holes. With a cobalt bit and a variable speed drill, I popped those out in 25 minutes. And that was only because I gradually increased the size of the bits through something like 5 increments.
I can't speak for the Neuspeed but when I compare the Autotech install to something like new springs and shocks or installing my Votex fogs, this is not rocket science.
Joe
Neuspeed is better. Dont drill if you dont have to! Might cause new problems!
I ordered my neuspeed front sway bar, now i am just waiting for it! :wink:
Discussion Starter #8
How do you know you do not have one :???:
i have the P&P rear sway, and you have to drill some holes, but it works amazingly, but i cant say anything about the autotech/neuspeed one, never used it..
I was leaning towards the Autotech Hollow Bars for my B5.5 but didn't want to drill and had heard that the Autotech bar were prone to have noise issues. I can't confirm that this true but didn't want to risk it. All in all though, I agree, lighter is better. The Neuspeed rear bar must weigh 30 lbs. or so.
The weight, IMHO, is negligible and doesn't make that much of a difference. These aren't F1 cars we are talking about here where grams come into play. As for noise from the Autotech, not a whisper in the 3 months I have had it on. On the drilling <shrug>, your guess is as good as mine. I really don't think a 10 mm round hole or the stresses placed on the axlebeam as a result of bolting the bar to those holes will make a difference. To each their own...
Joe
Autotech lightweight front and rear! (In a B5) :bow:
Front is noticably beefier than stock, but seemed to weigh the same - I was so eager to put it in and drive that I didn't bother to weigh it!.
(The front is a direct replacement for the stock bar.)
Rear was an easy install.
I used silicone spray lube on all the bushings and haven't had any noise issues after 2 years! :thumbup:
everyone is going to tell you somthing different...pros & cons but thats what you want.
i snagged an Autotech RSB used off here & have been happy every since!!
haha this thread is 6 years old, thats one hell of a bump!!:thumbup:
1 - 20 of 21 Posts
