1 - 3 of 3 Posts
2004 B5.5 Passat
Weather is starting to get nice and upon use of my sunroof yesterday I had trouble closing it. It appears the black plastic "wind gaurd", or whatever it's called, will not retract far enough when closing and causes the sunroof to open again.
Does anyone know if there is an adjustment for this or a replacment part that operates better?
There's no adjustment; that wind deflector is spring-loaded and just pushes down as the glass moves forward. Open the sunroof and look at the ends of the deflector - perhaps one side isn't fitted into the socket.
I had the same issue ice was blocking it from closing and as a safety it would open back up had to clear out the front and the sides completely for it to close, just check and make sure nothing is keeping it from closing. I'm positive something is in the way and try it. Hope everything works out.
1 - 3 of 3 Posts
