1 - 20 of 32 Posts
Need HELP changed Sus. and large drop??? Large drop??? Help
Ok I installed bilsteins and neuspeed sprots on sat and when I was done It was a 3 to 4" drop Vs the 1.5" drop???? What did I do wrong??
Left bum stops out and had the ring on the second setting too....It was lower then coil overs.....Anyone know What I did??
TIA
Discussion Starter #5 (Edited)
Well Its in the front and it is so low. It covers the top of the tire. I mean low I can just see the top tred of the tire so there was a good three in. drop. in the front. I have the right springs and shocks too. They came off a B5.5 V6 so it has a heavyer spring rate and the shocks are the same as the B5's. So I am at a loss :crazy: :crazy: :crazy:
"Well Its in the front and it is so low. It covers the top of the tire. I mean low I can just see the top tred of the tire so there was a good three in. drop. in the front. "
i don't see a problem here......
TIA
I just put the same springs on my 99 and got a 1.5-1.75 drop. Bump stops wouldn't do anything. I used the Koni's which don't have the adjustable ring so I can't help you there.
Tires at just a little BELOW the fender edge with 225-18's.
You say they "came off" another passat? So they weren't new? Are you SURE they're for the V6 model???
Don
Discussion Starter #8
Don
Yup They came off a B5.5 V6 which I called Neuspeed and they said the only diff is spring rate (B5.5 heavyer). So WTF...I need my car So I am going to have to put my stock springs with the bilsteins. Do you think that is bad to do???
Discussion Starter #9
I can't even put my fist under my belly pan. I have to turn it sideways amd it still a tight fit
Discussion Starter #11
I bottom out in my drive way.....and its level. It is far lower then coil overs and I don't have them. I can't understand what I did???? Right springs and shocks they were put together right??? I am going to have to put the stock ones back on and made get new ones later??
springs are always lower than advertised. i got the sofsports knowing other drops would be too low for the roads i'm droving on. i think they advertise .75" but it's really about 1.1" to 1.2"
Discussion Starter #13
It was about 3" they say only a 1.5 to 1.7 drop
you gotta get some pics !!!!! ive got the h&r race, which is supposed to be 2.5 drop but w/ the 19's i can get 2 fingers in the front and 1 in the rear.... ? it doesnt really sound like you did anything wrong, but i think pics would clear everything up for us...
-deez
that is titteeeee, u r lucky it slammed, i have mine on 19's if i was only lucky enough to mess up like u did ;) jus be happy n be careful around bumps..
and on driveways.
oh, speedbumps too..
rocks too.
actually, be careful everywhere
No. Shouldn't hurt a thing....other than your cars look :D
I know the bilsteins are adjustable ride height...maybe you can make a spacer disc that will get you up where you wanna be. I don't know anything about the bilstein installation but if they use a saddle cup for the bottom of the spring to rest on are you sure you have it "up"?
How bad is the rear?
Don
1 - 20 of 32 Posts
