I figured out most of the key, which helped a lot. I thought the line along the bottom was the ground connection?The beginning of the electrical section in the Bentley has a few pages on how to read their diagrams.
The little box with a number in it at the end of a wire shows the next connection. Those corresponding numbers are along the bottom. For instance. in yours above, #15 connects to #17. Sometimes these numbers can be pages apart.
Why does the forum eat most of my posts?That circuit board looks nasty. The bottom right pin looks to be missing most of its solder. I hate wiring diagrams, I had to buy a magnifying glass to read them when I had a Bentley manual.
Yeah, I suspect something might be wrong with the wiring to replace the connector on the blower control module (J129).* I don't have the tools to check it myself.Does it work after cooling down? Maybe some part of the circuit is failing when warm. I can't think of any reason why just removing/re-installing would fix things unless there is a dirty or bad connection somewhere.
The fuses should protect the wiring from getting burnt if the current is going through them. If something is getting hot enough to burn then either the fuse size is wrong or the current isn't going through the wires but taking an unintended path or there is an unintended high resistance point in the circuit.*I had a problem a few years ago where the connector on J129 got hot enough to scorch the sound insulation on the backside of the glovebox assembly, melt, and burn the insulation on the wires. I don't know if the J129 had failed or what, but I didn't want to leave it on continuously and melt another connector. I checked the connector and the J129 and they were not particularly warm. The J309 relay #385 was warm, but it was near the warm air duct and IDK if it is warm during normal operation.
