1 - 3 of 3 Posts
ok in parking lot car is armed but driver side door is unlocked press the unlock on remote will not unlock the doors however I can pop the trunk with remote. Try to start car and alarm is triggered and car will not start. I have fault codes like 00928, 01358. Is there away to disable the entire alarm so I can start it and get home.
Presume you figured this out? Personally I'd have tried disconnecting/reconnecting the battery if a better solution didn't present itself.
You have a fault in the driver side door latch module, and possibly with the CCM and it's wiring harness.
Try unlocking the car with the key in the trunk,mor passenger door if it has a lock cylinder. The alarm should disarm using the physical key in either one.
1 - 3 of 3 Posts
