I just got my car back from brake service and everything is fine...although for some reason the car just isn't pulling like it used to and the the engine hangs when i let go off the throttle...
here's the breakdown:
First gear....rev to 3k...shift to second...rev to 3k..shift to third....rev to 3500 rpms, let go of throttle and it hangs there for almost a whole second...then finally starts to come down....
i thought that maybe the mechanic put gas in the car and didnt put in 93...so i switched to stock mode...it still does the same thing except it doesnt hang as long....
is this a timing issue? or something more serious? I just changed all 4 plugs and a failing coil pack...I also just did the grounding mod to the battery...
99 passat 1.8t 5spd.
68K miles
91-oct. apr chip
