1 - 10 of 10 Posts
can anyone tell me how to change gear knob(manul) please...
i though i just need to twist it out, but i couldn't..... :cry:
thanx
2002-3 i think i did removed a clip under the knob,still wouldn't work but don't know if it is the one you are talking about...
you got any pics??
1. Pull out the bottom of the shift boot, it's just held in by a plastic ring, but be careful and remove it.
2. Lift the boot up and over the knob to see what's holding it on. It will either be a screw on (you'll see threads) or an evil looking crimp-on connector.
3. If it's the crimp on connector, use a flat bladed screwdriver and shove it in there until it's mutilated enough that you can get a pair of snips around it and cut it off.
4. When putting you're new knob on, use whatever fasteners they supply, or if it needs to be re-crimped on (In my case I put a Skoda knob on) Just use a really small hose clamp from AutoZone or PepBoys.
well i did the first step, and i don't see threads, which should be the crimp-on connecter.... and... the connecter you are talking about is a white plastic thing with an metal "ring"(clamp) on it right?? which i had to cut the connecter in order to take it off....
but still too tight.... can't pull the gear knob off
do i pull it or......
anyone got pics please??
yep...same proceedure, different knob. "Reverse" is different on G/J trannys.
Darin
what does the Skoda knob look like???
1 - 10 of 10 Posts
