2001 Passat, 1.8T AWM. B5.5
Coolant is leaking from the pipe next to the thermostat housing. I found a similar thread the AudiForums, but in that thread, no one could name what exactly the pipe is. I have gone through my Haynes manual as well, and I can't find an exact match. It looks like I may just need a new grommet. (EDIT: The grommet is split in two.) The pipe itself is aluminum.
There are no screws or fasteners on this line, just a rubber grommet. My pipe sticks out about the same as the pipe in the photo. I can wedge a prybar down between the manifold and leverage the pipe back into place, but it seeps water. I wanted a second opinion before I started removing everything to get better access to it.
My thermostat is busted open, but the t-housing isn't leaking. I blew a coolant line during the winter storm the past week, and I had to refill with water on the fly and the car sat in subzero temps for a few hours, ice formed around the t-housing, and ice is what pushed this out. I made it home, thank goodness, but the damage was done. I'm fortunate I haven't found anymore damage, but I digress.
Here is the photo from that thread. Mine is the same. Any help would be nice.
102403
I believe you need item 10, VAG Part N 903 653 02 in the Etka illustration below, presuming the leak is coming from item 9, 06B 121 065 AC, the coolant return pipe. I infer that item 10 is a 20x3mm "round seal", but it's not apparent exactly what it looks like. (click to enlarge the illustrations)
FYI, item 2 is the thermostat (which refers you to page 121-10).
You can search for the part numbers on ECS Tuning, for the pipe at least, for good pictures.
102411
102412
I name it Bob. I can't believe no one else named it :)
Yes, the 20x3 O-ring is what it needed. It's held in place by bolt #11 listed above. I expect it's far easier to remove the pipe and change the O-ring with the manifold out of the way. It's also a great time to overhaul the PCV, so I would add the intake manifold gasket and PCV to your parts list.
I replaced mine with Dorman 902-991 which came with the o-ring. It was $10 at Autozone. I left a review of the installation hiccups I encountered. You can't beat $10 with the o-ring. "Bob" was a bit of a PITA to replace but I did it without removing the manifold which made it harder so that may be why.
That's for the thermostat housing, not the metal pipe that going into the back of the water pump from the heater core.
