There is a possibility that the wiring to the sensor through the body is a problem.
All that aside, the car does look great, despite the incident.
Thank you, i will check that again just to be 100% sure.There is a possibility that the wiring to the sensor through the body is a problem.
I Dont think its bad because it does make Voltage when i measure the connection plugg, and i have changed it 2 times. I will take some pictures next time im in the garage.Or maybe the replacement sensor was bad since you tried redoing the wiring. Are you sure it’s fully seated as well?
Thank you 😁Wow, that looks super mean. Seriously impressed by that build, don't think I've ever seen a B5 look at good before.
Regarding rear disc upgrade:Hey!
Here is my 1998 Passat B5
Instagram:
Widebody_passat_biturbo
The car has a A6 C5 2.7l Biturbo AJK engine, widebody kit, H&R coilovers, 20 mm spacers, 19x10 et 35 Zito WP111, Continental Sport Contact 7 265/30 tiers with more...
I will make a modlist later.
This year 2022 have been a year full of problems. I hitt a deer the second drive i had and the engine failed (because of the deer) the third drive. So this year i have only been repairing the car.
Crash:
Today:
Current problems:
While i was working on the car i figgured i might as well uppgrade the rear brakes. The rear wheel hub housing is from a 2.7l A6 c5 and i figgured the 269/22 ventilated disc whould be a nice and easy uppgrade from my non ventilated discs. I got the 4D0 615 425 B caliper hanger and W8 Calipers. The problem i have now is that the caliper hanger dont match the depth of the rotor (54mm).
Does anybody know what caliper hanger i need?
I also want to fix a ABS problem i have had for many years. The fault code i get is 00287, open og short rear right sensor. I have changed rear abs sensor, abs unit, abs ring, and still same problem. When i trye to logg the wheel speed sensors the rear right sensor always read 1 km/h. I have connencted new wires from sensor to abs unit, when i measure volt i get low readings. I dont get why i cant get the correct readings from the sensor, any ideas are welcome.
Sorry for my bad english 😅 Looking forward to hear any ideas. There is loads more to write about the car, i will uppdate you![]()
Hello, thank you for replying, it is syncro/quattroRegarding rear disc upgrade:
You are FWD?
If you are, there is almost zero rear brakes upgrades for FWD. You will need to play with different brake discs height (offset ). Im also in reserch for rear upgrades but on B5.5😁
I would sugggest: 1. AUDI A6 (C5) ALLROAD rear disc is also 269x22 but different height
2.AUDI 100 (C4) QUATTRO 269x20 (non-vented)
3.Try adjust offset of caliper hangers by moving to outside or inside by putting shims or plate to match a disc
If you are quattro, there is much more upgrade options.Hello, thank you for replying, it is syncro/quattrowhat are your thoughts then?
Hey ofc.Can I ask where you sourced the bushings for your rear control arms and track rod?
Hey ofc.
Got them from Strongflex STRONGFLEX
