1 - 20 of 32 Posts
Cool! Great way to get those left lane bandits out of the way.
Man, I'd get in so much trouble with those...LOL 8)
Yep... Headlamp flashers indeed...
As S_Klass says, it's so illegal but just don't use it randomly on streets...
If I saw those in my rear-view while doing 90 on the highway, I might just sh!t myself. :lol:
Dude... I have been contemplating doing that for quite some time. I was afraid if I posted a question like that, I would get flamed up the yahoo for illegal activity... it apprears it is quite the opposite. How hard of an install was this? How is it activated... what materials were required and how much did they cost? Is this tied into the rear lights at all, or only the fronts? Do the highbeams still function? If there is a flasher tapped into the harness then wouldn't they just flash if you ran power to them?
my friend had strobes kinda like that, but instead in the headlamp and the corners. One night in a parking lot he had them flashing... forgot to turn them off, and down the street, cars were pulling over left right and center to get outta his way... until he got pulled over and got off with a warning. :lol:
-merk20vt-
Discussion Starter #11
Quoting VWPassatGLX155:
I've been flamed already by these guys so I've gone past that stage and I guess some have given up hahah...
For an electrical mod, on a scale of 10, I'd say it is like 6 as it took me efforts in removing the lower dash. It's not that hard really.
I had my lower dash removed as I was working on my brakelight switch, and then I just decided to wire my headlamp flashers since that was in progress.
I ran wires through instead of behind the ECU box this time round. Ran it behind when I installed my air horns. To open up the ECU box I had to remove my wiper blades and the plastic piece below it - easy for me as I've done it too many times (Past experience when I was replacing windshield, painting my car, etc.) Ran wires through the ECU box, that's about it.
A switch right next to the OBDII port. The black one on the right of the OBD port is it. (The silver one on the left is for my remote starter.)
<img src=http://home.waxedfruit.com/clubb5/hkpassat/highflashbtn1.jpg width=480>
What materials were required and how much did they cost?
Materials required:
- Headlamp flasher X 1 (From eBay; just do a search. Costed $25.99 with S&H&I.)
- Wire crimper tool X 1 (crimping butt connectors)
- Butt connectors X 5 (reconnect cut wires)
- Bolt-on connector X 1 (connect to 12V power source)
- Cable tester X 1 (to make hole on rubber to pass wire through ECU box)
- 8mm hex wrench X 1 (to dismantle lower dash and ECU box)
- Wiring diagram provided by the eBay seller
- Some form of a saw (to make a hole in the plastic part of lower dash for activation button)
They are seperate units. Though my tail light flashers are on the way.
High beams still function. They function normally when the flasher button is not in the ON/activated position. They do not function when the flashers are activated with the button.
Wires are not taped. They are cut and reconnected to the flasher unit, and new wires run out from the unit to the high beams. All wires were provided in the item I got from eBay.
S_Klass said:
That's cool but so illegal (in CA at least)
I would say illegal in all 50 states. Use of strobes/alternating falshing lights in a non-police vehicle is bound to be illegal everywhere.
There is a similar issue when civilians buy a P71 Crown Vic that is equipped with the strobes. Very illegal.
Couldn't see the video clips but I have an idea what you did and have to say I thought of doing this in my 99 GLS but in the corner lights. Cool :thumbup:
Materials required:
Very nice... Any idea if something similar could be done using the turn flashers for the emergancy lights (it would flash front and rear then wouldn't it...)? Tap a flasher unit into the Hazards... though that would be interesting if you stalled :p
Discussion Starter #16
I'm actually thinking about further wiring them into the lower grille fogs in opposite sides.
It looks more realistic with the high beams... the fogs are overdoing it... I was thinking about getting strobes for the grill to :lol:
I installed them on my old Buick. I used them a couple of times (once in the middle of the night on a deserted road, once in traffic to get a guy who was dragging a dog that had fallen out of the bed to stop). Luckily I was never caught!
1 - 20 of 32 Posts
