This is what happened to my unit until finally it went dead. You need to replace the unit.
Here are step by step instructions.
ABS Unit Replacement Audi/VW’s
After typing the same thing over and over again on posts, I have decided to write out the entire process from start to finish so I can just post this.
I performed this process for my dead ABS unit on a 1998 Passat 1.8T Automatic. No ASR, EPS, No 4 motion, No navigation system. The unit would not communicate at all with the VAG-COM. My ABS light came on and had a blinking brake light. This happened soon after I replaced my front brake pads. A year later, I decided to try and fix the unit.
Step1: Identify your problem: There are many problems that can cause an ABS light to turn on. A bad wheel sensor could be the culprit, but this seems to be less common. The more common problem is the ABS unit itself goes bad. In my case, the ABS unit went bad, and would not even communicate with the VAG-COM ( a computer program that hooks up to your car’s computer systems ) If you are interested in buying a VAG-COM for diagnostics, you can buy one for around $229, visit
www.ross-tech.com. If you don’t want to spend the money, search for someone in your area that has one using this website:
http://www.steve-hall.com/cgi-bin/VAG-Locator.pl Email them and ask for their help. Usually they will be willing to help for free, or if not for a small fee. If this fails you, you can bring the car to the dealer to pull the codes which will run you about $80. If your unit doesn’t communicate with the computer, or has some sort of fault with the actual unit, follow the following steps.
Step 2: Identify the part number of your unit: This is very easy to find. Open the hood, and stamped on the ABS unit (driver’s side, next to the windshield washer reservoir, is the unit) On the top will be most likely an 8E0 614 111 and a letter. These letters range from A-Z and sometimes have 2 or 3 letter combinations. Write this number down verbatim.
Step 3: Find a salvaged ABS unit: This involves lots of phone calls to various junkyards across the US. Use
www.car-part.com they have a huge list of cars by make and model. Search for your exact car first, searching for ABS pump, and call around to the cheaper and closer places first. If this fails you, search for different options, then different year cars, and then lastly your Audi/VW sister vehicle (these cars share parts quite often). You should expect to pay between $100 and $350 for the unit. If you find one in the upper price range, write it down, and keep looking for a cheaper one. Be sure to get at least a 30 day warranty. Most will give you a 90 day warranty. DO NOT by unit “as is”. You will find these guys, but other people will give you a warranty. Once you find your exact unit, have them verify the part number twice and have it shipped out.
Step 4: Test the unit (if you can) Before taking you car apart, the wiring harness that goes to the ABS unit can be undone and plugged into the salvaged unit un-installed. There is just enough wire to plug it in. The connector that holds the harness down has a pull-slot lock. At the very front of the connector, pull on the tab straight forward. This will pop off the connector. To plug it into the salvaged unit, you have put the sliding plastic piece about ¾ ‘s of the way in, push the connector nearly all the way on, then slide the connector to lock it in position. Run the VAG-COM on the ABS unit. If it communicates you are in business. Remove all fault codes at this point. They are from the previous car it was installed on.
Step 5: Replacing the unit What you will need to replace the unit, will depend on your plans. There are two ways to fix this unit: Most of the time, just the electronics go bad on these ABS units. Hence, you can just change out the electronics portion of the unit.
1. If you can somehow remove the windshield washer reservoir, you will be able to get to the 6 screws that bolt the electronics to the ABS pump. This may be able to be accomplished by removing the left front quarter panel. Once you have full access to all 6 screws, you are almost done! Take out the 6 screws and the bottom connector. The unit is completely sealed so you will not let air into the system when doing this. Remove the electronics and put the salvaged ones on. Reverse the order and you are done, no bleeding necessary!
2. I took out the my entire unit. When you take out the entire unit, you must first release the pressure in the system, by bleeding out the front left caliper. Put a cinder-block on the brake pedal so your fluid doesn’t run out. You will need a star-head screw driver, and some wrenches for the job. Buy a large can of DOT 4 brake fluid for later. Start off by labeling the locations of the 6 brake lines that enter the ABS unit. Get a bunch of shop towels ready for the fluid to start flowing. Not much came out on our re-install. Remove all 6 brake lines carefully. Undo the two nuts that bolt the unit to its bracket. Have a second person help pull the lines out of the way and pull the unit out. Remove the 6 screws that hold the electronics to the pump. The electronics are sealed so no fluid will come out. Replace the electronics with the salvaged ones. If you trust the pump is clean from the salvage yard, and/or you know you have a faulty pump, then replace the whole unit (pump and electronics). Again have your buddy pull the brake lines out of the way (be careful) and seat the unit back in. The two bolts on the sides must line up perfectly (they are slotted to the bracket). Reattach the 6 lines and tighten the brake lines pretty hard (be careful again)
Turn on the ignition and see if your ABS light is out. Mine was out at this point. If it isn’t out, there may be other problems. You may have to reset the unit that you got from the salvage yard with a VAG-COM before getting the light to go out. These fault codes are from the previous car it was installed on
Step 6: Bleeding the system (This does not have to be done if you didn’t take out the pump)
This is where things get a little complicated. Depending on what letter unit you have, you may have to bleed the pump first. This is done using the VAG-COM or similar unit. Use these posts do determine if your unit is “codable” for the ABS pump bleed.
http://1.8t.org/~quattroman/Audi B5...System OBD/01-128 Check control module 01.pdf
And
http://1.8t.org/~quattroman/Audi B5...System OBD/01-135 Check control module 07.pdf
If your unit is not “codable” then all you have to do is do a standard bleed.
If your unit is codable, then you may have to get a VAG-COM to run these codes according to your vehicle. Use this post -
http://www.ross-tech.com/vag-com/cars/absbleeding.html
There is a chance that you don’t have to do this step whether or not your unit is codable. I just don’t know
Once you are done coding or not coding proceed to these steps.
Now you must bleed the rest of the system. This is done with 2 people, a wrench, and an oil catch pan. You can choose to have the car’s 4 wheels off at one time or do one wheel at a time. One person will be in the driver’s seat, and one at a wheel.
Start at the passenger side rear wheel. Be sure your brake fluid reservoir is full. Start by opening up the bleeder valve and have the person start pumping the brake pedal slowly. Fluid should be spurting out the bleeder valve. At some point, you will see air coming out for a short bit. If you have dirty brake fluid, you will start to see clean fluid after the air. Pump through a good amount of fluid so that you know all air is out. At this point close the bleeder valve. Have the person pump up the brakes until the pedal is firm. Once firm, have the person hold the brake pedal down, while one person opens up the bleeder valve. BE SURE to have the person hold the brake pedal down to the floor and not let the pedal up before you close the bleeder valve. Do this 3 or 4 times to make sure all air is out.
Proceed to the driver’s side rear wheel, then passenger side front, then the driver’s side front. The order is important. Be sure between each wheel that your reservoir is not going empty. If it does, you must start all over.
At this point you are done! Put all the wheels back on. Do a drive test carefully.
