1 - 11 of 11 Posts
I realize this may be a long shot, but I figured I would try here, too, as I trust advice here more than most places. This is my wife's car, and she posted the question on newbeetle.org, as well. This is taken directly from her post:
A couple weeks ago, I ran some errands in my beetle (Louise's specs: 2.0L 5 speed manual, 2000, 49K miles). When I got in my car to leave, I turned the ignition switch over, but it didn't catch. So, I promptly tried again with success. I drove to my destination and after getting my shtuff, I pulled out of the parking space to notice that Louise was revving. I had my foot on the brake; the revs were between 2-4K rpms--back and forth, up and down. I turned it off, then couldn't get it restarted. After letting her sit for awhile, we got it restarted. No cel (which has come on 2x in the last month--my mechanic said he had to reset the codes--nothing that should have set the cel light off. Sorry, I don't have the codes!). About a week later, I had the exact same experience, except I let the car rev to see what would happen. It eventually remained at a normal idle, so I drove away. A couple of days later my cel came on. Thus, Louise is in the shop again. My mechanic (Andre) said that multiple codes all indicated that there is a short somewhere and he'll figure it out in the next couple of days.
:???: Basically, my questions are:
1. Have any of you experienced this problem or heard of it? Is there one place that can short that can cause multiple codes?
2. How did you fix it?
Thanks!
Well, my sister had a similar problem to this one. You don't say what year it is, but I know for a fact that early (98-99's) Bugs had a problem with the main vehicle ground coming detached or corroded. They should check that first.
Since they have fixed the ground in my Sisters Bug...she has had zero problems/codes. Believe me that is saying a lot. It used to CEL all the time and shut down completely. Once it happened on the freeway!
Good luck.
Edit: Sorry you said it was a 2000. Still might be the problem...
Discussion Starter · #8 ·
OK, the saga continues.
In short, our mechanic pulled out Kim's aftermarket radio (Kenwood Sirius receiver) and couldn't determine exactly what the cause was for the multiple short-to-grounds. He drove it for several days without the radio and, lo and behold, no CEL. We have driven it for about a total of 200+ miles with no CEL. We did some searching, found the K-line issue, and I think that is now resolved. Well, we put the radio back in, and within 15 minutes of driving around, the CEL comes on again. :(
We took it to Autozone to get it read, and here are the codes that it came up with:
P1255 Fuel-air meter is what it said on the reader, looking at the code table - Engine Coolant Temp.Circ Short to Ground. I don't know if I might have written down the number wrong?
P0172 - Running too rich
Is the radio still potentially causing this, or is it mere coincidence? What do I need to do to fix these on a NB?
Thanks so much for all of your help. You people ROCK!!!
Chris
ps - if there is more info that you need, let me know.
6th Grade
If you had a pile of short-to-ground codes, your fuel pump relay is bad/outdated and should be replaced with the newest version. The one you have now probably has a part number ending in B, and you want a C.
P1255=Bad coolant temp sensor. Replace sensor. The one you have is black, and now you want a green one. Don't question it, just do it.
P0172=PROBABLY your MAF, but it is pretty rare to see one throw rich codes; they usually throw lean codes. Might want to have someone really look at this.
The MAF will be a warranty item due to them sucking to begin with. The warranty on the MAF at the moment is 7/70, regardless of anything else.
1 - 11 of 11 Posts
