I decided today was a good day to try and figure out the pushrod length of the V8. In theory, I need a 6.250" pushrod for the 5.0L motor w/ hydraulic roller lifters. I had purchased an adjustable push rod checker for this purpose and set it to 6.250":
To ensure the roller rockers hit dead center on the valve stem, I used a permenant marker on the top of the stem, setup the rocker so there was no slack on the pushrod but not so much that it would pre-load the lifters. Then began rocking the rocker a few times from hitting the piston at TDC to full close; the idea is to "mark" the vavle stem tip so you can ensure it's dead center; too far to the exhaust meant the pushrod was too long. Too close to the intake means it's too short. As you'll see, it's pretty much dead center:
On an interesting side note, when I first bought the cylinder heads and hardware from the guy up in Sacto, I did not ask too much about the hardware. I knew it came with the head bolts and saw some studs but didn't really pay attention. Well today, I discovered I had gotten ARP head studs!!! These are $134.95 at Summit if they were new. This makes this purchase super inexpensive. Recall I purchased these heads with Comp Cam alum. roller rockers and now these ARP studs. Roughly speaking, this setup new, is $1500. My price for slightly used: $500. Now I'm really happy!!!
