Okay folks. I'm bout ready to start installing my amp for my front comps and rear sub.
Was looking at my Bentley manual to get all the colors for the speaker wires and wires to the amp straight (I'm going to use the existing wires).
Wires TO the speakers are all clear and the colors do correspond to what I saw when I replaced the OE speakers with my CDT comps.
But the wires from the HU to the Monsoon amp is what is confusing. My Bentley manual labels the pins with " speaker (or line out if equiped with Monsoon amplifier)" for all 8 pins.
Maybe I'm just stupid... but this tells me that the outputs from the HU are line level and not speaker level.
Supposedly the head unit has to be programmed by the VW shop under circumstances. Is it possible that they program it one way to be used with a Monsoon amp and a different way when used without a Monsoon amp??
http://www.continentalimports.com/acc_cable_out.html
This link shows several Blaupunkt adapters. I believe that the top one... the 4-Channel Preamp Output... is the one recommended? (I emailed them.. they don't know. It's supposedly for 10 pin connectors and the HU is 8 pin?? At any rate.. there doesn't appear to be any sort of hi level to low level adapter included in that. Just wires and plugs. (Unlike the High Level to Preamp Harness... which clearly shows some sort of adapter in the middle of the wires)
Can anyone help me here?? Is the output from the HU high level or not?? I don't know how to measure it. And which adapter do I need?? :???: :???: :???:
Thanks.
Thanks.
