I have a 2001 Passat with 4-motion and a 2.8l V8 that I am trying to find the ECU power relay for. If you take a look at the attached image you can see that I only have 1 relay in the ECM box. Looking at my VW manual I see that there should be a second relay behind the 373 relay in the picture. I removed the ECM and looked down the wiring holes to see if the relay fell down the hole but I could not find anyting. It is not that the wire is relay is missing, but rather that there is no place to connect the relay to. Were else could the relay be located?
Are the numbers on the relays constant? i.e. if I look through the rest of the relays for a 30, 428 or 429 will this be the ECM power relay?
