1 - 20 of 29 Posts
so i got a giac chip for awe tuning last week and installed the boost guage - i was hitting 20 pounds. last nite while i was drivin the check engine light came on and only got 7 pounds- checked it n said fuel trim to lean and o2 sensor so cleared that n got my boost back .. now today i can only get 15 pounds -dont know wtf is wrong or leakin ... need sum help or suggestions
Umm you have an overboost more then likely and the car has gone in to limp mode, what wastegate valve are you running. Also auto or manual.
If you have a boost gauge what does it say at idle. should read between 18-20 HG
20 Psi is to much, sounds like you wastegate didnt open fast enough. To much boost=lean hence the code. If this is a 1bar then you should only boost to 1psi.
Discussion Starter · #19 ·
so this would be considered over boost?
dammit was just gettin started to rip honda s2000 and and the new Si's
want my boost back
which n75 do i get?
Well boost the code first. The lean mean overboost more then likely. The car when running lean is bad=holes in piston, hence the reason you went in to limp mod.
I would search around. The auto I had had a ECs race valve n75 on it, its a repackage H valve basically. Its for sale cause I have a manual now.
1 - 20 of 29 Posts
