hi this is my first post after buying my first passat (i've had 3 polos and a golf gt-tdi). its a 2003 1.8t auto triptronic.
but i bought the car with the engine management light on. thinking that it just might need something small, i bought it quickly without checking it.
After driving it a couple days ive noticed that the car has a strange shake to it while its running. it doesn't seem smooth at all. Also when i put the car into drive there is quite a big jump, and the car shakes. (it goes into reverse fine without any problems) and while driving it doesn't jerk when changing up gears but it sometimes does it when shifting down.
I went to the mechanic the other day to diagnose the problem and 5 faults came up which included misfiring in the cylinders (1,3 and 4) these were reset but the one fault which remained was this one:
16486 - p 0102 MASS AIR SPORADIC
FLOW CIRCUIT -07
0:low input
So i need your help guys. Do i need to change the sensor, it doesn't seem to be a tough job from the looks of it. i called VW and the sensor is $235 CAD + Taxes) but i was wondering if that might not be the problem and would be pointless of changing it, if thats not the fault.
any guesses?
also will it solve my transmission problem?
thanks alot!
FLOW CIRCUIT -07
0:low input
any guesses?
thanks alot!
