I have a 2000 1.8T Passat with Split Second 1.8T Boost controler.
I just pulled my fault codes and here they are:
16795 P0411 Sec.Air Inj.Sys. Incorrect Flow Detected
16502 P0118 Engine Coolant Temp.Circ High Input
16684 P0300 Random/Multiple Cylinder Misfire Detected
16686 P0302 Cyl.2 Misfire Detected
17536 P1128 Long Term Fuel Trim mult.,Bank1 System too Lean
16891 P0507 Idle Control System Higher than Expected
17521 P1113 Bank1-Sensor1 Internal Resistance too High
17955 P1547 Boost Pressure Contr.Valve Short to Ground
That is the one that is scaring me. I figure my boost controller is acting up and overboosting the engine and thus running it too lean.
