I wouldnt say it was the low octane. I run the regular stuff in mine (I knowww) and have never had that problem. Maybe a little water in the gas?
If you're willing to let go a 2005 over a l'il ol' misfire, keep me in mind. Not all that uncommon, and usually not a serious issue.ps: anyone interested in a slightly used 05 wagon?![]()
hush you.seriously...who runs 87 in a 1.8T? You've gotta run 93 for optimum performance.
It should be; it's not particularly hard. That won't stop a dealer from charging you an hour and a half at $100/hr, though. But what you want to do is look in the plug wells to see if there's oil in there, before you consider it.I appreciate the feedback. Is a valve cover gasket something I could do in the drive way? Was looking yesterday and it doesn't look that bad. any idea what a shop would charge to replace it?
lol...read your email dude.hush you.oke:
If that turns out to be a (note I didn't say "the") problem, there's a larger concern. The valve cover gaskets usually leak because the PCV system is clogged. Experience has shown that system needs to be serviced every 4 years or so. If it clogs, pressure will build up, ruining the valve cover gasket and sometimes the cam chain tensioner seal. So you should do both systems together, which is kind of a tedious mess.
Six of one... last Toyota I had was relatively trouble free for 150,000 miles, whereupon the engine exploded. It ran, but it was the most boring car I'd ever owned. My 2000 Passat, OTOH, required some fiddling. But I looked forward to getting in it every day, and it's still going strong past 250,000 miles.Thanks for the insight. This is why I am not thrilled to have one of these cars as a daily family mover wife-mobile. I don't remember having the constant worries with my Yota.thing is...we have 2, an 04 and an 05. don't ask me why...
Just to add my .02 I had a Honda that decided not to start if it was parked in the sun and the outside temp was over 85. I lived with the problem for 5 years, trying to find parking under trees or underground as well as taking to every Honda mechanic and indy I could find a recomend for. Noone could find a problem. Turned out to be a diode in the ingnition system, $20.00.Six of one... last Toyota I had was relatively trouble free for 150,000 miles, whereupon the engine exploded. It ran, but it was the most boring car I'd ever owned. My 2000 Passat, OTOH, required some fiddling. But I looked forward to getting in it every day, and it's still going strong past 250,000 miles.
