i assume you have to go behind the tweeter in the sail panel, but what tool do i need? any special torque bits? anything i need to know about removal?
thanks again CB5!
You need to start by removing the interior door panel. For instructions on this, refer to the instructions for the AlienTech install on Stargazer's site - http://istargazer.ca/alien_remote/remote.htm
Just stop after you remove the door panel assembly. The tweeter and its entire housing will pop off gently with a screw driver and then you can disconnect it if necessary. As for the mirror assembly it is held to the window by one torx screw of a fairly large size....I think I was able to use a 8 mm allen to take it off though. This took me all of about 20 minute to swap in a new mirror a few weeks ago.
Joe
Guys,I have the dwarf right side mirror,which I want to replace with a 175 mm one.I ordered only the base frame and the blue tinted mirror glass.My intention is to use the In-Pro chromed housings.I wander how difficult job is to mount a mirror assembling the base frame with the housing?Any DIY instructions or photos or even advices,pls?
Assuming the In-Pro chrome housing is the same shape/size and has the same mounting mechanism as the OEM full-sized mirror...which it looks like it does....it is pretty simple.
The top housing just slides down vertically onto the lower base and mirror assembly. It then 'locks in' using a tensioned steel tab assembly. Question is whether you have electric mirrors and are planning on reusing the mechanical tilt assembly? That could make it a bit more complex....if not, you should be GTG.
