All other functions seem to work ie. power seat, heat etc, just the memory function not working. Where do I start looking?
My memory seat has its own mind since new. The dealer once told me I needed a new switch/buttons when I still had the warranty. I just gave it up of using it.
Self inflicted facepalm
It also doesn't self adjust when eveything is running [bad idea if were to adjust while you were driving because you dropped something on the bottons]. It has to be off first.
05GLX4moWgn
Join Date: Jun 2006Location: Solomons, MDAge: 67Posts: 1,290
Programming Memory Seats
I thought maybe I could clear up some confusion since I use mine for moving the seat back to write reports.
Do not put the key in the ignition until step 3!
1. Move the drivers seat max forward then max rearward.
2. Make sure the MEM OFF button is in the DOWN (off) position.
3. Put key in the ignition and fasten the seat belt.
4. Make your personal seat and side-view mirror adjustments.
5. Turn the key to ON, but do not start the engine.
6. Hold down button 1 until you hear the chime.
7. You're done, turn ignition off and remove key.
Your wife / GF / S.O. / BFF can now program their own memory by using button 2 or 3.
Check this Members guide. (secret handshake)
