1 - 1 of 1 Posts
I got this VW to replace a 535 BMW that was going to cost me a bunch to maintain To make the Passat more fun to drive I replaced the rear springs with H&R OE Sport Spring Set and replaced the sway bar with a 23mm bar , both from ECS . the car sits 1/2 inch lower in the back then before and is level with the front. The ride is just a little bit firmer and the car goes where you steer it, with most of the understeer gone. The Passat rewards smooth driving by not turning on the nannies while still carving the corners. There is a good balance in the wet or dry and if you try real hard you can rotate the rear. I had a few Sciroccos in the past and had forgotten how fun they were
1 - 1 of 1 Posts
