just got a Autometer phantom MAF and have a question.
Which O2 sensor should be used to obtain the signal for the air/fuel gauge ?
The one closer to the exhaust manifold or the other one?
which wire is the signal ?
there are 2 white wires , a grey and a purple. on the conector
Use the O2 sensor before the catalyst.
The stock VW sensor is heated and so has 4-wires. The diagram I have indicates that brown is ground. Not sure how to map the stock wires to your wires.
thank you.
I decided to try the sensors cause i was impatient .
wired to the wrong one ( got lean reading )
I will wire to the right one now.
BTW
Ground= Brown
White: heater
White= heater
Purple= signal
