I have just cleaned my injectors on my NA 1.8 ADR using an ANSU injector cleaner.Does anyone have any experience or advice on using the ultrasonic bowl to just clean the two wire of the MAF.These could be submerged after unbolting (the torx tamperproof screws)thehot wires from the plastic moulding.The conventional advice seems to be use a cotton bud(Qtip)and Isoproyl alchohol on the wires carefully
The main reason for carry out all this is an emission test failure in the UK (the MOT)Both the fast idle and normal idle showed readings of approx 2.5% CO and Lambda of 0.93.So I concluded the system was overfuelling i.e. rich .
I don't have access to a fault code reader VAGCOM etc but have checked the sensor values of the air & Water temperature senders,they appear to be OK for resistance values.
Is there anything else I should check or do before I hand over the car to a dealer,for their diagnosis
TIA
TIA
