1 - 11 of 11 Posts
2
Guest
engine Mercedes Benz M180 V12 w/Pagani Intake, Exhaust, Management Systems
position Mid-Longitudinal
aspiration Natural
valvetrain DOHC, 4 Valves per Cyl
displacement 7291 cc / 444.9 cu in
bore 91.5 mm / 3.6 in
stroke 92.4 mm / 3.64 in
power 484.7 kw / 650 bhp @ 6200 rpm
torque 1057.54 nm / 780 ft lbs @ 4000 rpm
redline 7000
drive wheels RWD w/Traction Control, Self Locking Differential
body / frame Carbon Fibre Monocoque with Aluminum Sub-Frames, Carbon Fibre Roll Bar
front brakes Carbon-Ceramic Discs w/6-Pot Calipers, Hydraulic Assist, ABS
f brake size 385 mm / 15.2 in
rear brakes Carbon-Ceramic Discs w/4-Pot Calipers, Hydraulic Assist, ABS
r brake size 385 mm / 15.2 in
front tire size 225/35x19 Michelin Pilot Sport 2
rear tire size 335/30x20 Michelin Pilot Sport 2
steering TRW Rack & Pinion w/Power Assist
f suspension Alunimum Alloy A-Arms w/Pull-Rod Springs, Olhins Adjustable Dampers, Anti-Roll Bar
r suspension Alunimum Alloy A-Arms w/Pull-Rod Springs, Olhins Adjustable Dampers, Anti-Roll Bar
wheelbase 2730 mm / 107.5 in
length 4435 mm / 174.6 in
width 2055 mm / 80.9 in
height 1141 mm / 44.9 in
transmission 6-Speed Manual w/Twin Plate Clutch
looks good to me. the ONLY complaint is that front wheel-gap. but i dont car enough to turn this thing down!
Used to not care for them too much, until I saw (heard) that video of a bunch of them parked on the street and one of them was ripping back and forth past the camera. Never heard a better exhaust note. Effing ridiculous!
Cargasm. I love the concept of unpainted carbon fiber bodied cars. make more...MORE! That front fender gap makes me feel better about my car.
The Zonda may be coming to the US soon.
Unfortunately the V12, in its current state of tune, cannot pass US regs. Word has it that a turbo or supercharged V8 will be in the US spec car. Which is a real pitty since much of the car's driving personality is based on its instant naturally aspirated scalpel-like sharpness.
1 - 11 of 11 Posts
