1 - 14 of 14 Posts
G
Make Aston Martin
Model Vanquish S
Tuner Mansory
Engine Location Front
Drive Type Rear Wheel
Body Material Carbon Fibre & Aluminum
Introduced At 2006 Essen Motorshow
Engine
Engine Configuration V
60-degree
Cylinders 12
Engine All alloy.
Aspiration/Induction Normal
Displacement 5935.00 cc | 362.2 cu in. | 5.9 L.
Valves 48 valves.
4 valves per cylinder.
Valvetrain DOHC
Horsepower 520.00 BHP (382.7 KW) @ 7000.00 RPM
Torque 577.00 NM (425.4 Ft-Lbs) @ 5800.00 RPM
HP / Liter 88.1 BHP / Liter
Compression Ratio 10.8:1
Fuel Feed Twin PTEC engine management system controllin
Standard Transmission
Gears 6
Transmission Manual
Dimensions
Seating Capacity 2
Doors 2
Exterior
Length 183.701 in | 4666 mm.
Width 75.701 in | 1922.8 mm.
Height 51.901 in | 1318.3 mm.
Wheelbase 105.901 in | 2689.9 mm.
Vehicles with similar dimensions
Suspension
Suspension Independent double aluminium wishbones
Steering
Rack and Pinion with Power Assist
Brakes
Front Brake Size 405.001 mm | 15.9 in.
Rear Brake Size 330.001 mm | 13 in.
Tires / Wheels
Tires Front : 255/35/20
I'm Urlik's Hero
Lord knows how the Teletubbies can afford one of those.
Ok, I'm am all about AM but this just doesn't do it for me. I don't care for the wheels or the rear valavnce. IMHO
You are going to have to lust without me on this one....
I am not feeling it with all the Pontiac Grandprix inspired bodywork.:puke:
So horribly overdone. And where are the brake rotors?
1 - 14 of 14 Posts
