I get odd things all the time. Right now I keep getting the following:
1st code - MAF reading below lower limit.
2nd code - Oxygen sensor - 2nd bank - below limit, resistance too high.
All of this is a product of a bad MAF, the first code is right, but not because the engine is starved for air, but because I have a crapy MAF. The dealer is fighting me on it. - Mod the intake and they tell you that is the reason, never mind the KNOWN MAF issues with the 1.8t. I have swapped it our with a good one and no code...so you decide.
Anyway back to the point - so the other code is a result of the MAF reading incorrectly. The rest of the sensors process bad information and throw more codes. The car runs fine, but the codes keep showing up.
One bad reading at the top of the line will result in more as you move throught the system. I alwys try to fix the top of the system and usually the rest falls in line.
Rusty - I will be there. Two sets of tires and a helmet :thumbup: what else do you need.
