Looking for space for my Audiocontrol OVERDRIVE line driver up front?
I am adding this and everything I have read indicates that it should be installed up front, close to the speaker level inputs. Is there room behind the glove box? The unit is only 5" x 4.25" x 1.25" so it doesn't need much space. Can I just remove the glove box and install it behind?
Re: Looking for space for my Audiocontrol OVERDRIVE line driver up front? (GolfDad)
It should fit behind the glove box with out a problem. There is a bit of room back there. I have the brain For my nokia car kit mounted back there.
Did you order your Overdrive on line if so where?
HTH
Pete
Re: Looking for space for my Audiocontrol OVERDRIVE line driver up front? (Bmpassat)
I Purchased a new OVERDRIVE on Ebay for $65.
I mounted my Phoenix Gold Line Driver (about the same size as your OVERDRIVE) inside the glovebox to the roof of it since it does require adjustment. If I was the "set-it-and-forget-it" type of guy it would be mounted in behind the dash, but since I'm constantly tweaking so I put it somewhere with easy access.
