1 - 2 of 2 Posts
Hello I need to get to the to the blend door level on my manual control a/c unit. Now that its cold out had low to no heat to defrost the car yesterday. As I drove the car for and hour I could feel good hot heat but seemed to be blocked from coming in full blast in any confutation of the settings. So i think the door is not opening completely. I have seen thread about the bushing going bad, hopefully thats all it is. I know it under the dash behind the radio area and I need to pull the glove compartment but If someone has a diagram of how the peices fit together I can plan my attack.
Thanks and Happy Holidays
If you look under the pass side you can see the one that is most likely bad, it has a red arm. I have to tap mine for it to move.tap it and see if that is the bad one, I have to hit it pretty hard soemtines but it will move.there is a hole near the center or the dash underside, you will see it
1 - 2 of 2 Posts
