Hello everyone, I tried almost everything and still had issues with this.. If I push the bottom down of the master switch for the rear windows they goes up, If I push it up, they goes down o_O .... CCM check, wiring check, window power motor rear ones changed them both, ... if someone can give me any advice would be really appreciate it
Thanks!
:bowdown:
Master switch was removed, and I found "smooth work" in here 20140612_084009.jpg 20140612_084026.jpg
My guess is those wires are from the aftermarket alarm and those contact at the board makes the lock/unlock function. Of course I need a new master switch and the possibility that the windows are insane and working the opposite as they should pretty sure its for the switch.
Now, which ones wires are for unlock/lock function? where is the best place to join that ones in the board?
Thanks!!!
