Is the driver door, puddle light on when door open and off when door closed ?
With interior light set to door, does it go on when door opened and go off soon after the door is closed ?
It is likely that the door open switch or its wiring is faulty, see below.
But it could also be a faulty CCM or its wiring.
If you remove the door lock module, be sure to re-solder all connections on the PCB.
Ensure the lamp is good before testing the rest.
If the puddle light ever comes on with the door closed, the "door open switch" is almost certainly not functioning correctly.
If the puddle light ever does not come on with the door open, the "door open switch" or its wiring (including solder joints on the PCB) is almost certainly faulty.
Front Door Lock (Rear doors are similar)
You should lower the window into the service position (2"-3" open) before you disconnect the battery.
No need to remove the window completely, just tape it up securely. (Put paper/plastic over top of door to protect paint)
Door Lock Mechanism Repair (With Pics) (Modified copy from www.taligentx.com)
Also check the wiring and connectors between the doors and pillars.
All Doors
Additional information on the "puddle light/door open switch".
forums.tdiclub.com
All Doors
Stupid door Switch!! $3 Fix!!!
I have my drivers door all tore apart. I am trying to fix my door switch. The one that tells you if the door is open or not and turns on the interior lights and the door light on the door. I have determined that the little switch that does this is bad since it fell apart when I removed the lock...
