...about an oil change. This is in regards to a 2004 GLS 1.8t. On the drain plug bolt, there's a washer. This washer doesn't come off - it will not slip off the end of the bolt and can't be "threaded" off. With the OEM oil filter came an aluminum crush washer. I asked a tech at the VW dealership about it and he said to cut off the washer that's on the bolt now and replace it with the aluminum crush washer.
When I did the first oil change I simply left the washer that was on the bolt in place and shelved the crush washer. I was in the hurry and didn't want to do something stupid. There have been no leaks and no problems with just leaving the washer in place that came on the bolt.
So, now that I'm doing another oil change, should I cut the washer off that's there now and replace it with the aluminum crush washer? Should I simply put the crush washer on, putting both in place? Should I stuff socks in the drain plug hole and leave the bolt out all together? Should I go drink beer, pass out, and not worry about changing my oil?
I am doing the oil change today and heading out of town tomorrow, so I'd appreciate a quick reply. I appreciate any help you guys can give me!
Abe
Abe
