1 - 3 of 3 Posts
Friends car has been acting up scanned it with vag-com, i think its the first o2 sensor as the maf was just replaced, what are your thoughts. It's a b5.5 awm
VAG-COM Version: Release 409.1-US
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,57,58,76
Address 01: Engine
Controller: 4B0 906 018 DP
Component: 1.8L R4/5VT G 0003
Coding: 0016501
Shop #: WSC 03158
4 Faults Found:
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 008 - Implausible Signal
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded - Intermittent
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 002 - Lower Limit Exceeded - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded - Intermittent
Readiness: 0000 1000
Address 03: ABS Brakes
Controller: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00022
Shop #: WSC 00028
No fault code found.
Address 15: Airbags
Controller: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0001
Coding: 12345
Shop #: WSC 00028
3 Faults Found:
01222 - Crash Sensor Side Airbag: Passenger Side (G180)
30-10 - Open or Short to B+ - Intermittent
62-00 - No or Incorrect Adjustment
27-10 - Implausible Signal - Intermittent
Address 17: Instruments
Controller: 3B0 920 927 B
Component: KOMBI+WEGFAHRSP VDO V08
Coding: 07235
Shop #: WSC 00000
WVWPD63B83P047789 VWZ7Z0B5434537
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway KCAN 0001
Coding: 00006
Shop #: WSC 00028
Address 46: Central Conv.
Controller: 1C0 959 799 C
Component: 08 Komfortgerát HLO 0001
Coding: 00259
Shop #: WSC 00028
Address 56: Radio
Controller: 3B7 035 180
Component: Radio NP2 0055
Coding: 00401
Shop #: WSC 00028
End --------------------------------------------------------------------------------------------------
· I Know Stuff
B1 S2 or its wiring is faulty, but that won't effect performance or cause the other codes.
If you used an after-market MAF sensor, that is probably the main problem.
Check the entire intake system inc. vac lines, for air leaks.
He didn't listen to me and bought a maf on eBay gonna swap his out with mine and see if it's solved, thank you
1 - 3 of 3 Posts
