21 - 26 of 26 Posts
Discussion Starter #21
DriverFound
Thank you !
It's simple mod, desolder original Red LED and switch to Blue one.
Just be careful not breaking the circuit board when taking apart the tip switch.
Discussion Starter #22
daigo
Yep, it makes me fun to drive :D :D
Where did you get the light-weight pulley from?
If you got from ASP, I heard their 1.8T pulley has some fitment issue.
:suspicio: :???:
Kokopelli,
Mine is ECS made. AEB,ATW and AUG will fit, so probablly my APU will fit also. ECS pulley could be an ASP-OEM, so I'll search for ASP site for the fitment matter. 1.8T has A/C belt and generator belt, could be a TIPS for these 2 belts... :eek:h:
kokopelli said:
DriverFound
Thank you !
Thanks - what is needed to get to the LED? How does the Tip surround come out?
Discussion Starter #25
Taka apart whole center console, shift lever and pry off Tabs "B", now you can see the back side of the circuit board that adhesive taped inside of chrome shift gate part.
Carefully take of the circuit board, you can access the small LED tip.
Be careful, tab "B" and the circuit board are easy to broken, need to buy whole expensive shift gate assembly to replace
hope this will help :)
21 - 26 of 26 Posts
