Oh yeahIf I swap the whole thing (key+electronic) into a new plastic case, will i still have to reprogram? or is it not "swapable"?
not a bad idea...I need a couple as well..
I only see one seller who has them on ebay, located in taiwan.
shipping is $12 to the US, but additional shipping is only 5. we could set a little group buy for this maybe?
Could you do a write up?planB: cheap fix like I just did on both my keys today..
took them appart, made sure that i was clear to drill. drilled. done.
when you open the key you can see the 'seal', which makes the key somewhat waterproof. I just made sure to drill the holes outside the sealed area (where electronic is located)Did you do anything to make sure the FOB is atleast water resistant?
