1 - 20 of 25 Posts
Max Boost: 24.2 psi
Max Power: 192 hp
Max Torque: 261 Ft/Lb
I've never done this before, but I'd do it again. It was pretty darn exciting!:Yikes:
B5 or B5.5? Nice Tq!!!!! Good numbers all the same.
Resident a-hole knowitall
got a run down engine mods, numbers look real good i would have expected more than 200 at the wheels but with torque like that who cares about the hp.
Discussion Starter · #6 ·
Yeah, I think I agree with you. I was really hoping to put down 200 at the wheels, but I was happy with the torque.
Engine mods are:
K04-015
GIAC PC-16 file
Genisis 315cc injectors
3 Bar FPR
ECS lightweight crank pulley
EVOMS intake w/ ITG filter
APR TIP/TBP
Custom FMIC using a Garrett core
Bailey DV w/ Forge cold side relocate
Turbo back exhaust (Evolution Racewerks TP, Techtonics DP and exhaust)
Boost Valve MBC
...and that's it, I think.
I just got my pc16, I got a couple more things to do be for I hit the Dyno! Hope I get the tourqe numbers the hp i'll be happy for 200, I tightened the waste gate a little more then the factory had it
I'm in MN everyone is doing e85, Helps huge cooling down intake charge throw some more timing at it! So tempting 1fish2fish is running it.
Engine mods are:
K04-015
GIAC PC-16 file
3 Bar FPR
APR TIP/TBP
Boost Valve MBC
What psi you got it at 24? and at 6500 whats it at? Your intake air temps also would be really great also:poke:
Did you guys let it cool down between pulls? Could of been heat soaked makes a good diffence 10whp
can i ask how many psi it was before u added the MBC and also why u use a MBC?
Me too cause I got mine done with the stock inter-cooler I was seeing over 20 spike when now I'm seeing 16 across the board I checked vacuum lines and all looks good I'm putting the front mount in in 2 days, I hope this will solve the problem with a leak If I got one
Discussion Starter · #16 ·
I was getting about max 16-17 psi before the MBC and that amount of boost would hold strong for a while before tapering off in the upper RPM band.
The first reason I chose to run the MBC was for more boost(thus, more hp and torqe). It did exactly as I planned, with the only downside being the boost tapers off much quicker than before.
I haven't found a similar 4cyl setup in my town that can get me from a roll yet. :cool: The torque feels really nice and comes on strong. I don't know if I would recommend a MBC with a K04, its just one of those "to each his own" type of situations. In case you're wondering, I run it in parallel with the
N75 valve, not bypassed.
No, 24 PSI would be a spike around 2500-3000 RPM. After that, the turbo just couldn't supply enough air to pressurize the manifold to 24 PSI.
1 - 20 of 25 Posts
