So i bought k04 hybrid (compresor inducer is 42,5mm),and i need to drive 100 miles to first tune shop .
Can i drive until there if i stay below 2000rpm or even then i can damage something . Engine,turbo or something else?
Ps.
I have stage 1 on stock k03 turbo.
No problem with running a k04 without the correct tune. The ECU will regulate boost as it sees fit per the current tune.
Thanks.
I alredy see that when you upgrade to k04-015 you dont need a tune .. its driveable, im asking because is slightly bigger than normal k04-015.
Should i have any problems?
Should be fine if you don't install larger injectors or higher FPR before the tune. Just keep it under 4K.
