21 - 25 of 25 Posts
Discussion Starter · #21 · (Edited)
Just put in stiffer motor mounts yesterday....wow what a difference in the power transfer and drivability. At idle there is more vibration, but once you get going, it drive beautifully. If you can live with the vibration at idle, I would go with them no questions asked.
Resident a-hole knowitall
it will get better as you drive and break them in, i found the vibrations very very bad on initial startup but after a week of driving it was much much better
Discussion Starter · #24 ·
So the portion of the mount that wasnt solid anymore was the bottom portion where the bolt attaches to the mout itself. the rubber portion was fine
Discussion Starter · #25 ·
Im in need of some help with vag com, particularly in the fueling portion but overall as well. I want to do some logs with vag com to check how eveything is looking, mainly fueling, but other that anyone could suggest to check on things would be great. The more detailed the instructions the better. Thanks in advance.
21 - 25 of 25 Posts
