1 - 2 of 2 Posts
Hello everybody. I have a passat b6 2.0 tdi 140. BKP engine from the year 2008 with a 6 speed dsg transmission. I have a problem of jerks and hesitation when the engine is cold, it is as if the diesel or the air is cut from the engine. when the engine reaches a temperature over 70 celsius the problem disappears and the car drives normally. moreover, I have the impression that the problem appears when I drive the car and I park it after 3 or 4 hours. because at the first start it does not. no fault code. thanks for your clarification.
2017 Volkswagen Passat 1.8T S
If the car is jerking when it's cold, it's the transmission not the engine. You should do a transmission filter and fluid service and see if that helps.
1 - 2 of 2 Posts
