It's leaning out for some reason, maybe an air leak after the MAF, or maybe low fuel pressure. The air leak is more likely, so start taking a careful look at the whole induction system, from the duct leaving the air box, to the hose connection at the throttle body. Also, look at any hoses and check valves leading to the intake manifold. You may have to pressurize the intake path to find the leak, if there is one. This can be done by using common PVC pipe plugs of the appropriate sizes, from the hardware store. One plug needs a Schrader (tire inflater) valve to allow your tire pump to pressurize, but carefully so as not to exceed say 20 PSI.
