That looks pretty damn good but ya gotta show some daytime pics.
oke:
VGA adapter to a composite input , trought my GEXp700TV tv tuner , the picture is pretty good. ( not like the SVGA monitors off course but pretty good)Paradigm said:Is that monitor connected with a VGA connection, or normal RCA's?
Paul , I think you Alpine HU has 1 or 2 AV inputs so it should work fine .quality_sound said:Fabio - Which Pioneer screen is that? I haven't seen that before. The computer looks pretty sweet! :bow: Why did you run it through the HU instead of right out to the amps? Could I run something like this through my C801?
Paul :thumbup:
I have a VAG COM and it will be conected to part of the system.that thing is so sweet! do you also have vag-com?
1.8Tabamoura said:Paul , I think you Alpine HU has 1 or 2 AV inputs so it should work fine .quality_sound said:Fabio - Which Pioneer screen is that? I haven't seen that before. The computer looks pretty sweet! :bow: Why did you run it through the HU instead of right out to the amps? Could I run something like this through my C801?
Paul :thumbup:
the screen is a AVD505 I had to use my HU for 2 reasons , the screen needs a Brain to control it and i did not want to loose the TV tuner which is also controled by the HU .
FAbio
quality_sound said:1.8Tabamoura said:Paul , I think you Alpine HU has 1 or 2 AV inputs so it should work fine .quality_sound said:Fabio - Which Pioneer screen is that? I haven't seen that before. The computer looks pretty sweet! :bow: Why did you run it through the HU instead of right out to the amps? Could I run something like this through my C801?
Paul :thumbup:
FAbio
I'm going to pick your brain for a bit if you don't mind.How do you control the computer? What kind of ballpark figure would I be looking at to build the CPU?
I do have a second input I'm not using so it'd be an easy input. Also I could free up the one I'm using if I rip the DVDs to the HD. Your setup is looking like an ideal way to go for me. I can continue by PM if youd prefer.
Thanks!
Paul :thumbup:
