I have 2002 VW Passat and I have recently bought a VAG KKL usb scan tool I could not install the vag-com drivers 409.1 as they will not work with Windows 10. I finally got some working drivers for Windows 10. However vag-com and vcds light will not detect the interface it finds the com port. I have used Carport diagnostics free version that dose work but is limited as you can not erase the fault codes. Can any one tell of any other diagnostic software that is free that I can try that will allow me to erase the fault codes.
