1 - 8 of 8 Posts
Hi all
First reg July 2002:- 2 litre S b5.5
Just noticed today that the exhaust baffles in the silencer are making a noise as if they are loose, car in for 20.000 service tomorrow will they fit a new silencer under warranty???
Thanks for your help
Tony
Just had another look at the exhaust doesnt sound like thwe rear silencer,(vibrating sound under high revs), sound coming from near the front, any idea`s?? :???:
Also:-
Just rang VW UK, exhaust is not covered only cat converter (even though car is 20 months old and only at 20.000 mls) :crazy:
Any tips guys
Tony
They are :crazy: . It should be covered under you bumper to bumper warranty. Just listen carefully to narrow down the area and then check for anything loose underneath. Heat shields on the cat and exhaust manifolds are known to rattle.
Discussion Starter #8
Got this from VW UK website:-
The Volkswagen Warranty guarantees your car should it require repairs following sudden failure covered by the terms and conditions of this warranty. Replacement parts and labour will be paid for with the following understandable exceptions:
Routine servicing (all parts replaced associated with routine servicing are excluded)
All bodywork and glass
Wear and perishable items as follows:
All adjustments
Batteries
Bulbs and fuses
Exhaust system (catalytic converters are covered) :cry:
Interior and exterior trims
Non-genuine manufacturer's parts
Tyres and wheels
Un-encased drive belts
Wiper blades and arms
Wiring and connections (including HT leads and aerial co-axial cables)
Worn brake discs, drums and frictional material
Worn clutch pressure plates, bearings and frictional material
Looks like they are right!! :mad:
1 - 8 of 8 Posts
