1 - 16 of 16 Posts
I am going to order an exhause this week and was wondering if the high flow cat is worth it to get. It runs anothe $500 so I really don't want to spend the money if I won't get the gains from it.
I am getting chipped with new DV next Saturday, but that is it as far as mods go.
$500 for a high flow cat is a rip off, where are you getting it from?
$500.00 is quite expensive for a high-flow catalytic converter. If your original cats are in good shape then don't waste your money, but if they need to be replaced go with a Magnaflow Catalytic Converter Part#: 22935. This unit runs about $200.00US and is OBDII compliant and a direct-fit for 1.8T Passats. :thumbup:
I've had good luck with Magnaflow high flow cats in the past.
It won't give you as much gain as the exhaust. Modern cats are pretty free flowing. But at $200 it's not a bad idea.
Looks a lot like the Randon Tech cat, although it's easy for external appearances to be decieving on this item.
1 - 16 of 16 Posts
