Has anyone here added a pump and lines for an IC mister? I know some have done it for FMIC, but has anyone done it for the stock side-mounted IC? This seems like a fairly easy and inexpensive mod that can help reduce heat soak.
The link below shows how someone did it for a Jetta. In that example the mister is activated using a button mounted in the cabin. Anyone have ideas on coming up with a temperature controlled method of activating the mister.
http://forums.20vturbo.com/viewtopic.php?t=16506
Retired PassatWorld Staff
Chas, paging Chas.
Hopefully he'll chime in. His home grown mister has gone thru several revisions, and has turned out very nicely. It's on a FMIC, but the application is the same regardless of the position... and it's temp or manually controlled.
PassatWorld Staff
A bump for Chas. His home-grown mister works pretty well. He must be busy or something, otherwise he would've chimed in by now. If you're really interested, PM him. You could also search for "mister" or "mist", also posts from "Chas".
does anyone know how to make one for a fmic or is there a place that sells them?
