1 - 3 of 3 Posts
1999 Passat V6 Automatic. Instrument Cluster Lighting Up, Vag-com And Mechanic Says Its The Circuit Board Behind The Instruments And I Have To Replace The Instrument Cluster, Which Costs About $600. Does Anybody Know Some One That Can Fix The Circuit Panel? Don't Trust My Mechanic Too Much.
As Soon As The Tachometer Stops Working,the Oil And Check Engine Light Up And All Kind Of Whisels Start, Checked The Oil And Its Perfect.thank You.
Punches Dubs. True Story
Check the CCM under the front passenger's seat. Any chance you've gotten some water in there recently? (Could be a bad seal with the cabin air filter.)
1 - 3 of 3 Posts
