Hi! I changed the leds from my instrument cluster, but the light is to bright. I want to change the resistors, but I dont't know which are and how many ohms to be...
Some help? Thanks
I've seen write-ups on this subject, however it looks like a fair amount of work to get to the LEDs. If there are individual resistors for each LED, these should be un-soldered and replaced with higher resistance ones. The new LEDs will have a specification for the Voltage drop across them when lit, as well as a recommended current. For a rough example, if the supply voltage is 12 Volts, and the LED's operating voltage is 2 Volts, then 10 Volts must be "dropped" across a resistor. Supposing that the intended current is 0.01 Amp, then use Ohm's law to find the resistance needed: R=Volts/Current, or 10V / .01A = 1,000 Ohms.
You can also just measure the resistance of one of the removed resistors, and try doubling the value to see if the brightness reduces enough.
ylwagon's advice still holds but now the resistor is sized based on the drop across all 3 LED's. For example, 12V supply, 6V voltage drop across all 3 LED's, intended current = 0.01 A (10 mA).
Use Ohm's law again R = 12-6 V / 0.01 A = 600 ohms.
