1 - 3 of 3 Posts
Im going to be installing an innovate lc-1 http://www.innovatemotorsports.com/products/lc1.php :D in my 1999 passat 1.8t any suggestions with the installation? any links other than this site http://www.innovatemotorsports.com/support/manual/LC-1_Manual.pdf Also im going to be installing an adjustable fuel pressure regulator http://www.ecstuning.com/Volkswagen-Passat_B5-FWD-1.8T/Engine/Fuel/Pressure_Regulator/ES5704/ which fuel line do i splice so i could fit the gauge? and how do you adjust the fuel pressure regulator....... under WOT? Basically I'm installing GIAC PC-16, 310 injectors, and what i mentioned above :thumbup::thumbup: Im talking any suggestions and advice, thnks:lol:
Here's where I installed mine
Here's the fuel pressure regulator and inline gauge.
Getting the gauge installed is easy. Just pop the hose off and bring it to any shop that installs hydraulic hoses and such. Get it crimp fitted, put a T fitting and pressure gauge on and you're set. As for adjusting the fuel pressure, you'll have to do it at idle since you can't reach under the hood at WOT.
1 - 3 of 3 Posts
